0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 24 New Guy | | New Guy Joined: Jul 2011 Posts: 24 | What tires would be the best for my 1947 1/2 ton pick-up (216) bias ply or radials? Someone told me radials will make it wonder some and bias will be better, but I question my source as he seemed to be more noivce than me! (If that be possible) | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I would suggest you try a search of the archives, as this has been talked to death. After reading several hundred posts on the subject you need to weigh the pros and cons offered by radial as opposed to bias ply tires. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Radials will make it drive MUCH better, with no wander. They are the best choice if you're going to use the truck regularly. If you want a stock appearance for shows, and don't plan on driving it as a daily use vehicle, bias will be ok, buth they will not perform anywhere near as well as a modern radial. Also, radial will be much cheaper, as virtually all bias construction tires are considered "specialty tires", and are priced higher than a comparable size/load range radial.
Bill Burmeister | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Radials. Period. If the truck wanders, check alignment.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2011 Posts: 24 New Guy | | New Guy Joined: Jul 2011 Posts: 24 | thanks will check ailiment | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | After checking the alignment, check the air pressure. Over inflation will cause wandering. My radials wandered until I decreased by 2 psi until the wandering stopped. 38 psi with LT215/85R16 - I forget what psi I used with 7.00R15LT.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Wildone...let your novice friend wonder while you wander, OK? | | |
