Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 135 guests, and 4 robots.
Topics128,275
Posts1,058,572
Members48,492
I see a lot of trucks like mine with the sides of the hood removed. It looks like to remove them, you need to hammer/pull out the pin in the hinge. So my question is, after you've removed the sides, how do you hold the hood down, since the latches/locks are on the hood sides?
1940 Chevy 1/2 ton, 12 volt, 350/350th
Bungi cords?
Give me ambiguity
or give me something else
Blah. I was hoping there is a cool trick way to do it, or maybe someone came up with a way to make a hidden latch or bracket.
With out a picture I have only imagination to work with since I don't think I've ever seen one up close.
I did wonder if it is possible to re-purpose the original ones but that required more specific knowledge again... so you get Bungi wave
(Someone with what you need will be along shortly)
Give me ambiguity
On my Model A in the summer months I remove the lower part of the hood(sides). Just as you said - remove the hinge pin. Then reinstall a new pin in each end(4 total) in the shape of an L. The leg of the L goes in the "hinge" the other leg is held to the firewall and the radiator by clips with 1/4 turn fasteners. I'll try to snap a pic and post later in the week.
....David
stevebolt, that's where being a streetrodder comes in! You will have to fabricate some hold-downs for your application. Be creative. Bungees are NOT cool!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Ahh shucks.... I was trying to avoid the baling wire idea too even though it would be more period correct. I guess thats how the first hot rodders evolved, they had a need and evolved past what was at hand to what would be cool...
Give me ambiguity
