| | | Forums66 Topics128,292 Posts1,058,590 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | I see a lot of trucks like mine with the sides of the hood removed. It looks like to remove them, you need to hammer/pull out the pin in the hinge. So my question is, after you've removed the sides, how do you hold the hood down, since the latches/locks are on the hood sides?
1940 Chevy 1/2 ton, 12 volt, 350/350th
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Blah. I was hoping there is a cool trick way to do it, or maybe someone came up with a way to make a hidden latch or bracket.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | With out a picture I have only imagination to work with since I don't think I've ever seen one up close. I did wonder if it is possible to re-purpose the original ones but that required more specific knowledge again... so you get Bungi (Someone with what you need will be along shortly)
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | On my Model A in the summer months I remove the lower part of the hood(sides). Just as you said - remove the hinge pin. Then reinstall a new pin in each end(4 total) in the shape of an L. The leg of the L goes in the "hinge" the other leg is held to the firewall and the radiator by clips with 1/4 turn fasteners. I'll try to snap a pic and post later in the week.
....David
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | stevebolt, that's where being a streetrodder comes in! You will have to fabricate some hold-downs for your application. Be creative. Bungees are NOT cool!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Be creative. Bungees are NOT cool! Ahh shucks.... I was trying to avoid the baling wire idea too even though it would be more period correct. I guess thats how the first hot rodders evolved, they had a need and evolved past what was at hand to what would be cool...
