8 members (JoergK., MickeyP, EchoBravoSierra, FAST55, Forty9, Joe H, 55shaker, 1 invisible),
43
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | anyone know where to get gasket set for a cc-300 1941 1-1/2 ton 4 speed trans gasket set... I have read stuff about it being built heavy duty... anyone know what they did to make it that way,,, and are the gaskets the same as a 1/2 ton 4 speed gmc... thanks katrina
I like fixing stuff.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | In 1941, a 4 speed was a 4 speed. The only difference in them was the torque tube setup for smaller trucks and an open end on the larger trucks, plus a COE had a slightly taller shift tower on some models.
The gasket set should be the same and I imagine almost any of the vendors sell them.
Jeff | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | or go to the local flaps and get some sheet gasket stock and make your own... | | |
