8 members (Hotrod Lincoln, sudsyz, Chip O, Gdads51, 1955 1 Series, stlcardinalsguy, tclederman, 1 invisible), 67 guests, and 0 robots.
Topics128,210
Posts1,057,456
Members48,471
I have a 1966 k10 that has a good leak out of the speedo cable where it treads to the transfer case. It is a rockwell t221. I removed the cable and the gear and gear sleeve and see no seal anywhere.Can someone tell me what I'm missing.
Thanks Al
ODSS Lawman
ODSS Lawman
The seal!!
There has to be some kind of O-ring or paper seal in there to keep the oil from leaking......
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Could the transmission be overfilled? I thought the speedo cable exited the transmission above the oil level.
The transfer case is not over filled. But looking in the shop manual I have it apears that the speedo gear and cable should exit on the top side of the housing and towards the drivers side. Mine exits from the bottom and towards the passengers side. I think it might need to be spun if the 4 bolt pattern is equal.
i solved my problem. i took the speedo gear housing(metal coupler threaded on both sides) and had a machinist bore a hole to fit a speedo seal from at turbo 350. works great!!!
Alstepside
Hi Al,
I just came across your post. I have a '62 K10 with the exact same problem. My transfer case is leaking like a sieve, where the speedo cable connects. Mine also exits from the bottom and towards the passengers side. And there's no o-rings whatsoever. I saw that you had a machinist bore a hole (to fit a speedo seal from a turbo 350). Any advice on how to do that? Size/etc?
Thx,
Wayne
__________________
'62 K10 Fleetside
I am also listening. Does anyone have pictures of this mod or a part number for the cable seals (if they exist)?
~ HB
1962 Chevrolet C10
1962 Suburban
