4 members (Chip O, Hotrod Lincoln, TooMany2count, 1 invisible), 88 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#861381 06/23/2012 12:58 PM
Will the factory 261 PCV system bolt right up to a '59 235?
If so,'Anyone got the parts and pieces?
Thanks!
Rick
Rick O #861390 06/23/2012 2:58 PM
ODSS Lawman
ODSS Lawman
The quick answer is yes.
Obviously you will need the valve cover, air cleaner, plumbing, and draft tube. I have these parts if interested, send me a PM.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #861406 06/23/2012 3:49 PM
The factory PCV system for a 235 will also work on any 235.
In both cases, the air cleaner would have to match the top of the carburetor that you are using; and, the PCV valve cover from a pre-54 235 would require the use of two rocker arm valve-cover attachment bolts.
Rick O #861414 06/23/2012 4:04 PM
DADS50 #861497 06/23/2012 10:27 PM
Bitchen'! Thanks for replies and links!
