0 members (), 133 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
#860507 06/20/2012 1:38 AM
I have 47 1.5 ton. I have frame blasted and painted. Has anyone put a newer front clip on one of these? What is best way to get modern steering and brakes and ability to change wheels and tires? I was thinking 3/4 ton front end? Could it be welded up as one unit? Ideas???
Unless you're willing to narrow the crossmember and shorten the relay rod between the steering gear and the idler arm, most modern front clips will be too wide for your fenders. With a fair amount of welding skill and a pretty good understanding of steering geometry, that's not an impossible job, but it's not a drop-in fit by any means.
OK other than that are there any good ways to get new brakes/steering under one of these? Mustang II? Is that heavy enough for a truck this size?
I'd like to have disc brakes and power steering as well as newer wheels and tires.
Is it an early 47 or a late one?
I put a 78 3/4 front end under my 48 two ton.It was all bolt in.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Late
