1 members (Paul Mullen),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 5 New Guy | | New Guy Joined: Jun 2012 Posts: 5 | I have 47 1.5 ton. I have frame blasted and painted. Has anyone put a newer front clip on one of these? What is best way to get modern steering and brakes and ability to change wheels and tires? I was thinking 3/4 ton front end? Could it be welded up as one unit? Ideas??? | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Unless you're willing to narrow the crossmember and shorten the relay rod between the steering gear and the idler arm, most modern front clips will be too wide for your fenders. With a fair amount of welding skill and a pretty good understanding of steering geometry, that's not an impossible job, but it's not a drop-in fit by any means. Jerry
| | | | | Joined: Jun 2012 Posts: 5 New Guy | | New Guy Joined: Jun 2012 Posts: 5 | OK other than that are there any good ways to get new brakes/steering under one of these? Mustang II? Is that heavy enough for a truck this size?
I'd like to have disc brakes and power steering as well as newer wheels and tires.
| | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | Is it an early 47 or a late one? I put a 78 3/4 front end under my 48 two ton.It was all bolt in.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Jun 2012 Posts: 5 New Guy | | New Guy Joined: Jun 2012 Posts: 5 | | | |
