| | | Forums66 Topics128,181 Posts1,057,180 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | The cylinder for the passenger door lock came out in PO's hand 2 days before I picked up the truck. I have the cylinder, a sleeve with slots in it, and a spring. I've tried various combinations of insertions, and turns to try to get it to 'lock' into the door handle. Anyone have experience with these? Thanks! Tom | | | | | Joined: Feb 2000 Posts: 5,237 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,237 | Here is a picture from the parts manual, http://chevy.oldcarmanualproject.com/1929_54chevyparts/16/758.HTMThe roll pin on the left side of picture holds it all in place. Ok, not sure that is right, I've been looking at the picture and really don't remember how I got it together, I do know there is a roll pin that holds something in place. Joe
| | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Hmmm, I have the cylinder, the spring, and the case....guess I have to take it all apart, and see what else I can scr...FIX! | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | If you can't get it together, these do come up on Ebay from time to time.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The "clip" and the "pawl are the two parts most people lose when working with the parts of this door handle. The other trick is put the parts back together and inside the handle with out them coming apart. You actually have to tie or wire the parts together to get them in the cylinder. Don't tap or lightly hit any of the small parts during assemble. They are made of pot metal and break easily. Find the oldest locksmith you can find and he might be able to do it!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 64 | Abxtc If you haven't got it scr....fixed yet, let me know. I'm a third generation locksmith. Been playing with these things for quite some time. James
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
