1 members (Ponchogl),
132
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | I did some searching but couldnt come up with anything concrete.
I'm looking into getting the offenhauser 3 carb intake on my 52 3100 with a 235. I will be running 3 Rochester b carbs on it. My question is does anyone know if there will be firewall clearance issues on the third carb or the linkage? Has anyone else ran this setup that had any issues with it?
Thanks, Wade
52' Chevy 3100 5 window
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I believe there is firewall and fender brace issues with the rear carb. | | | | | Joined: Oct 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 71 | Holy overcarburation..... a 235 with 3 Rochester B's ! That should be an interesting tuning session !!!???!! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Just a note that you might want to blank off the fron and back carb, so you get the luck without the over-fueling, if it becomes an issue. | | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Keep the fire extinguisher handy. It's going to spit, bog, and backfire, and it won't have enough power to get out of its own way. If you trailer it to the car show, and push it on and off the trailer, it might work that way. Jerry
| | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Get a 2 carb offy, preferably the 1034 216 model with "Buffalo" adapter rings, use SAE 2 size Carter W-1s or YFs, get better milage and power, and still look good, imho. Even the big NASCAR Hudsons only used 2 carbs. 3 Bs on a 235 is WAY overcarbed. http://www.thecarburetorshop.com/Carbshop_articles.htm
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Come on guys, getting multicarbs to run just takes time and patience and the right tools to get them working together correctly.
To answer the initial question, the fender brace will get in the way. Sometime cutting out the brace and replaceing the section with a horseshoe will make it all work fine.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | Thanks for everyones input. I ended up getting a fenton dual carb intake.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | No comment on the clearance issue.
As to 3 carbs on a six cylinder, a properly thought-out and tuned system will run GREAT! Those who might disagree might look at the Jaguar XK-E or the Austin Healey 3000 as a couple of examples. There are many others. However, 3 Rochester B's on a basically stock 235 is grossly overkill!
A wee bit of homework will pay huge dividends.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | No comment on the clearance issue.
Jon. Referring to 2 english cars as examples of "properly thought out" and "well tuned" isn't helping your case. Just kidding, sorry, I had to do it. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | No comment on the clearance issue.
Jon. Referring to 2 english cars as examples of "properly thought out" and "well tuned" isn't helping your case. Just kidding, sorry, I had to do it. Good point, however there are no Lucas electrics in the carburetors!  Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | I've done a buttload of work on Zenith, Stromberg, and SU "constant depression" carbs. The reason they run so well on Brit cars is the same design feature a Quadrajet has. The spring-loaded floating pistons and the Q-jet air valve won't let the engine get over-carbureted. No matter what the driver does with the gas pedal, the carb is as close to idiot-proof as possible. Rochester B's and even Carters can be overriden by an impatient driver's right foot. Jerry
| | | | | Joined: Jun 2008 Posts: 19 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 19 |
Why is there no mention of progressove linkage? I run 3 Ford 94's on my 302 GMC with no problems at all. I used Speedway Motors progressive linkage to save myself the time and trouble of making the indifidual levers on the three carbs. It's set to come in at about half throttle,and at that RPM there's no overcarburetion, just power.
On a separate note, I've heard that the Carter W1s are better suited to Multiple Carburetor setups. Something to do with the sensivity of the power valve on the Rochesters | | |
