2 members (Gdads51, 68ironhead),
174
0
Mod | | | Forums66 Topics128,110 Posts1,056,251 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Should I have 4,5, 0r 6 quarts in my 235 engine? | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | It may depend on the application; whether it's in a car or truck, or if it's an early or late 235. What specific 235 do you have? If you know what vehicle it came in you might be able to access an owners manual or shop manual here. If you don't know what it originally came in post the stamped serial number and casting numbers and we'll try to help ID it.
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | And, it depends on the size of the oil filter, if you have one (and if you empty it when changing oil).
| | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 5 gts for the 6 cyl, 2 additional qts for a filter .... you will find an Operators Manual usefulBill | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I usually fill them with oil till they reach the FULL mark on the dipstick. Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | 5 quarts will get you safely started, if you have a filter, it will fill up and you can check the level, then add to fill if necessary. Then you will know. | | |
