1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#859908 06/17/2012 8:50 PM
U
U Offline
Should I have 4,5, 0r 6 quarts in my 235 engine?
uncleb #859914 06/17/2012 9:09 PM
It may depend on the application; whether it's in a car or truck, or if it's an early or late 235. What specific 235 do you have?
If you know what vehicle it came in you might be able to access an owners manual or shop manual here.
If you don't know what it originally came in post the stamped serial number and casting numbers and we'll try to help ID it. smile
Professional Novice
Frank50 #859922 06/17/2012 10:03 PM
And, it depends on the size of the oil filter, if you have one (and if you empty it when changing oil).
U
U Offline
'58 engine, no filter.
uncleb #859939 06/17/2012 11:58 PM
5 gts for the 6 cyl, 2 additional qts for a filter .... you will find an Operators Manual useful
Flxible #860248 06/19/2012 2:10 AM
1 Offline
I usually fill them with oil till they reach the FULL mark on the dipstick.
5 quarts will get you safely started, if you have a filter, it will fill up and you can check the level, then add to fill if necessary. Then you will know.
