5 members (dt235sd, 3B, Waveski, Otto Skorzeny, 1 invisible), 91 guests, and 4 robots.
Topics128,266
Posts1,058,140
Members48,482
V
V Offline
We got a battery tray from Bowtie Bits and it is way (about 5/8") too narrow. I tried to bend the legs out on it to make it fit and the rivets holding it together popped out. What an expensive piece of crap! The only way I could see making it work would be by re-drilling the holes in the frame (which would necessitate welding the old ones shut). I shouldn't have to do this on something that cost over $50 and is listed in the catalog as a "reproduction". I get so tired of these so-called reproductions that aren't worth the boxes they came in. Is there any one of these parts that is good enough quality to install as it should? Thanks.
I've not purchased one for an Art Deco in a long time but JimCarter has been in business long enough that one would think he'd have corrected a bad box. Give them a call and see what they say..... but in all honesty I'd give Bowtie Bits a call and see what they will do. I suspect all are made by the same mfg. company but then we never know.
Try the link below. You may have to copy and paste it in your address window and it will take you to Carters. Good luck....and let us know What Bowtie Bits does for you.
http://www.oldchevytrucks.com/cart/product.asp?prodid=FL185&i=9881|||
V
V Offline
Okay. Thanks.
Hope you have better luck with the battery box than I did with a new grill for an AD.
Mine is welded up 2 x 2 angle, bolted to inside of frame
1940 Chevy KC 1/2-Ton
Hello, I bought mine from "Classic Parts of America." I had no trouble with it. The only thing I had to modify was the battery hold down bracket. The angle strips on the corner were really close to the battery post. Wasn't a problen to modify. If you are using a 6-volt battery I bet you would have no trouble. Just my thoughts. My last catalog list the price as $44.95 for the box,$11.95 for the battery top retainer. May be more by now but as I said it bolted right in. Good luck.
PS: You could make a simple bracket to hold the battery down. Probably you may have a piece of scrap around the shop.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
V
V Offline
Thanks. I'll look into it.
Got mine from Carters and had same bad experience as vegiguy - rivets popped out.
1960 GMC 1/2-ton Fleetside
"Donald"
More pix on Flickr
1941 GMC 1/2-Ton Short Box Stepside
"Wilburforce"
More pix on Flickr
1943? Chevrolet G7107
1946 Dodge COE 1-1/2 ton
1939 Allis Chalmers model "C"
Just my 2cents but the battery tray is a great place fo a DIY welding project,nobody will ever see mine on my 46 but i,m still proud of it.BTW it cost about $0.20 worth of welding wire and some flatbar I had laying around the shop.
I'll be going the same route as you, welding a angle frame to mount the battery behind the cab, in frame rail on my 1942 1.5 dump. I just want easier access since the truck will be doing more sitting than driveing
