10 members (KEVINSKI, Goach2, 55shaker, Maybellene, Gray_Ghost, Guitplayer, Peggy M, 60steve, GradyB, Jeff Ogden),
128
Mod | | | Forums66 Topics128,204 Posts1,057,297 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | Last night we hung the drivers door on the 64- in anticipation of getting outer body panels on and aligned for final fit/ bodywork and paint- I have new hinges on the drivers door- as the old ones were pretty loose and causing fits with the latching when we first received the truck- So- new hinges in and the door swings nicely now- but if we adjust to where panels line up - the top of the window frame sticks out past the body of the cab by 1/4" we installed the new weatherstripping ( not glued in yet) and I and thinking it's a bit too wide or stiff or thick or something- because if we remove the stripping the door closes ok- (I have door latch issues but we are looking for a replacement latch assembly) In any case- will this weatherstripping compress more over time and allow the door to sit flush? Passenger side is next and I am anxious to see if the weatherstripping is going to be an issue on that side- any thoughts? | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i installed new weatherstripping on both my 63 and 64 and it was a tighter fit after that, and yes it did compress a little after a while. but it was quite a change from the old weatherstipping. | | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | Hoggyrubber,
Did the window frames on your doors kinda stick out a bit from being flush with the body until the gaskets compressed a bit over time? with gaskets on my door sticks out farthetr than I think it should... | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I had the same problem on my '65 after replacing the hinges and seals. After countless tries and running out of family memebers, freinds, strangers, and anyone else that I could get to help hold the door while I made slight adjustment, I took it to a body shop that specializes in old cars. The owner chuckled and said they changed the foam forumla years ago and the seals were too hard. He claimed only a few companies were using the original formula. For $75 he replaced the seals and adjusted the doors. They look factory fresh.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | yes it did cause the doors to stick out a little. and it put a little pressure on the latch too while it was shut. they have compressed some over the last few years. never as good as it was new, but i'm no professional anyway. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I ran into the same thing, bought another brand of rubber and it's great now. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | IIRC, it was from Classic Parts of America. | | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | I think I might just get a new set of weatherstripping from Classic Parts of America- IIRC- we have to just about slam the doors for them to close and the drivers door is sticking too far out- I'm done trying to adjust the doors to fit right ( well- maybe one more try) only to have the door stick out too far... thank you for the heads up on the other rubber source!
| | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | | | |
