3 members (KEVINSKI, cmayna, 1 invisible),
108
Mod | | | Forums66 Topics128,175 Posts1,057,055 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Hi All, I have a 1946 Chevy 1/2 ton stock, and I would like to change my front brakes from huck to bendix. I have a 1952 GMC Suburban that I want to use for the donor brake parts. Are they compatible? Thanks, Possum | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | GMC and Chev are the same. Should be a good candidate.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | just swapped my 46 1ton huck brakes to bendix setup.The difference was night and day.Best thing I have done so far on my truck other than going from bias ply tires to radials.Probably better saftey upgrade than the tires. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | I have a 48 GMC 1/2 ton short bed pickup.
I replaced my front Huck's brakes with Bendix brakes off of a 1952 Chevy pickup.
Spindles are the same, just make sure you get all the parts from the spindle out Especially the spacers behind the backing plate.
I have not changes the rears on mine yet.
Made one heck of a difference in stopping power.
I would advise replacing the GM style ball bearings with the newer tapered roller bearings. Kits are available from several online sources.
Good Luck GMCPic
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Hey GMCpic, Can the rears be changed as well? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I can tell you it would take some real creativity to change the rears over to Bendix. First the backing plates are riveted on, but more of a problem is the flange that they attach to is in a different position.
