2 members (Steelonsteel, Wooley), 141 guests, and 2 robots.
Topics128,167
Posts1,057,020
Members48,458
Hi All,
I have a 1946 Chevy 1/2 ton stock, and I would like to change my front brakes from huck to bendix. I have a 1952 GMC Suburban that I want to use for the donor brake parts. Are they compatible?
Possum
GMC and Chev are the same. Should be a good candidate.
My Blog
just swapped my 46 1ton huck brakes to bendix setup.The difference was night and day.Best thing I have done so far on my truck other than going from bias ply tires to radials.Probably better saftey upgrade than the tires.
I have a 48 GMC 1/2 ton short bed pickup.
I replaced my front Huck's brakes with Bendix brakes off of a 1952 Chevy pickup.
Spindles are the same, just make sure you get all the parts from the spindle out Especially the spacers behind the backing plate.
I have not changes the rears on mine yet.
Made one heck of a difference in stopping power.
I would advise replacing the GM style ball bearings with the newer tapered roller bearings. Kits are available from several online sources.
Good Luck
GMCPic
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
Hey GMCpic,
Can the rears be changed as well?
I can tell you it would take some real creativity to change the rears over to Bendix. First the backing plates are riveted on, but more of a problem is the flange that they attach to is in a different position.
My Blog
