8 members (2-Ton, DadsFirstPickup, 32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50), 73 guests, and 2 robots.
Topics128,049
Posts1,055,661
I definately want front disc brakes on my 1965 1/2ton stepside. But before I open my wallet, I gotta ask - Will I still be able to use the factory steel wheels after I convert to disc brakes? Is there enough room for the caliper? ohwell
Not the o.e. wheels, got to get to '71 for disc brake wheels.
BC
1960 C60 pasture art
Are the 1971 wheels 6 lug? I really want to stay with 6 lugs. Thanks.
R Online: Content
It depends on which disc brake kit you get and from what supplier. Some use a 12" rotor which will not clear the inside of a stock wheel. The 11" rotor kit should clear but I would check with the supplier. If they can't tell you they don't know anything about their product and I would stay away from them.
Fred
1/2 ton 4wd are, 2wd 5 lug.
BC
Looks like I'll have to hunt some down then. It should be fun trying.
Jay, I THINK the chev blazers used 6 lug for a long time. Not sure about the years.....just a thought.
It seems the main issue is backspacing. I have some nice mag rims with about 4" of backspacing and I believe they should be fine with disc brakes. However, I also like the steelies with wide whitewalls look too and am undecided as to which one to use.
Anyone know how much backspacing is required for disc brakes?
The basic steel wheel was used from '71 - '87 on many K1 pick -up & thru '91 on K1 series blazer / jimmy & suburban. Remember, even if a rig has alloy wheels it would have have a steel spare!
BC
After a good night of sleep, I realize that backspacing probably has nothing to do with fitment. I'm thinking that it's got more to do with the size of the rotor.
