| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Been playing with my truck (Maters Cousin)trying to get it sound enough for a twenty mile jaunt. Have drove it around my little town a fair bit and decided to try a secondary highway! Top end of 45 mph! It has the 4.56 gears and 4 speed trans. Transfer case is not installed as the PO installed (cobbled) the 4.56 rearend and made a two wheel drive. when I get teh correct rear end (3.90) installed, w/transfer case(Rockwell) will/should I expect improvement? I really hope so! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 4.56 was the 3/4T, 3.90 gears will help a lot, my 58 w/ 283 and 3.90 rear will cruise at 65-70 comfortably [if noisy].... it's a 4x4? is the front axle ratio stock?
Bill | | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Yes, front axle is the stock NAPCO unit. stock 3.90 gears. I have no idea why the PO pulled the rear axle assembly and installed the 4.56! He apparrently pulled the transfer case and driveshafts at the same time as they were in the pickup box. Like I stated, he made a two wheel drive, sorta! Sounds like getting the correct rear axle under the truck will definatly help! Thanks Bill! | | |
