4 members (WICruiser, Gray_Ghost, Bill Hanlon, Nick in Manitou), 125 guests, and 2 robots.
Topics128,109
Posts1,056,269
Members48,439
Replumbed my brakes on my '70 C-10 this weekend. New lines, master and wheel cyl. Bench bled master and bled lines but still have low, spongy pedal. Will I need to keep bleeding as air works its way out?
53 Dumpy
1951 Chevy 3100 "Ernestine"
1970 Chevrolet C10 "Ol' Blue"
1940 JD "long-hood" B
1959 Jeep FC-170
1960 IH B275
2013 Chevy Silverado
2023 GMC Denali 2500HD
Did you replace the rubber lines as well? Sometimes they get soft and cause your problem.
best wishes,
Les
Yep, new hoses, too. Everything new stem to stern.
53 Dumpy
1959 Jeep FC-170
1960 IH B275
Make sure you have rear brakes adjusted correctly
1940 Chevy KC 1/2-Ton
I had the same problem with my 65 when I converted from a single master to a dual(for obvious safety reasons). With all the new lines and hoses it took forever to get all of the air out of the rear of the system. After a long gravity bleed, I still had to bleed the rears multiple times to eventually fix the soft petal problem.
