1 members (klhansen),
146
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Replumbed my brakes on my '70 C-10 this weekend. New lines, master and wheel cyl. Bench bled master and bled lines but still have low, spongy pedal. Will I need to keep bleeding as air works its way out?
53 Dumpy
1951 Chevy 3100 "Ernestine" 1970 Chevrolet C10 "Ol' Blue" 1940 JD "long-hood" B 1959 Jeep FC-170 1960 IH B275 2013 Chevy Silverado 2023 GMC Denali 2500HD
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Did you replace the rubber lines as well? Sometimes they get soft and cause your problem.
best wishes,
Les | | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Yep, new hoses, too. Everything new stem to stern.
53 Dumpy
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Make sure you have rear brakes adjusted correctly | | | | | Joined: Jan 2009 Posts: 27 New Guy | | New Guy Joined: Jan 2009 Posts: 27 | I had the same problem with my 65 when I converted from a single master to a dual(for obvious safety reasons). With all the new lines and hoses it took forever to get all of the air out of the rear of the system. After a long gravity bleed, I still had to bleed the rears multiple times to eventually fix the soft petal problem. | | |
