0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#85778 10/27/2003 6:29 AM
Anyone seen this one?
Left tail lamp works fine, blinks when blinker is on , gets bright when you hit the brake. Right one is a different story. Its very bright all the time, as if you had the brake depressed however if you take the bulb and insert it where it will not stay it works fine. Any suggestions?
#85779 10/27/2003 9:53 AM
Either the bulb is wrong or the inside contacts have twisted. May have the wires hooked up wrong to that side?
#85780 10/27/2003 8:57 PM
I checked the buld and it looks like a 1157 however it does not say that on it. I bought some new bulbs this morning. I will try it out tonight and see what happens. I hope its not wiring. If it is then that will be the excuse I need to take off the bed and have some fun with a san blaster smile
#85781 10/27/2003 9:11 PM
"MONGO"
"MONGO"
Could be a bad ground, you'd be surprised the way's electricity will find a path when the normal one's not there.
Find where your light grounds to the frame and take out the screw, wire brush the contact and the frame till they are shinny put on a layer of petroleum jelly and screw it back together.
Bet that will fix it up. I've seen similar behavior in that case.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#85782 10/27/2003 11:55 PM
I will give that a try. I will let you know how it went.
