| | | Forums66 Topics128,034 Posts1,055,544 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85778 10/27/2003 6:29 AM | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Anyone seen this one? Left tail lamp works fine, blinks when blinker is on , gets bright when you hit the brake. Right one is a different story. Its very bright all the time, as if you had the brake depressed however if you take the bulb and insert it where it will not stay it works fine. Any suggestions?
Thanks | | |
#85779 10/27/2003 9:53 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Either the bulb is wrong or the inside contacts have twisted. May have the wires hooked up wrong to that side?
#85780 10/27/2003 8:57 PM | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | I checked the buld and it looks like a 1157 however it does not say that on it. I bought some new bulbs this morning. I will try it out tonight and see what happens. I hope its not wiring. If it is then that will be the excuse I need to take off the bed and have some fun with a san blaster  | | |
#85781 10/27/2003 9:11 PM | Joined: Jul 2000 Posts: 621 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 621 | Could be a bad ground, you'd be surprised the way's electricity will find a path when the normal one's not there. Find where your light grounds to the frame and take out the screw, wire brush the contact and the frame till they are shinny put on a layer of petroleum jelly and screw it back together. Bet that will fix it up. I've seen similar behavior in that case. MONGO | | |
#85782 10/27/2003 11:55 PM | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | I will give that a try. I will let you know how it went.
Thanks | | |
