4 members (Frank50, frogfarmer, klhansen, Otto Skorzeny), 84 guests, and 4 robots.
Topics128,077
Posts1,056,012
Members48,433
#857775 06/09/2012 4:53 PM
I am trying to figure out which 6-CYL I have in my '47 ('46 Style) Big Bolt (1.5 Ton).
I am told that it is a 292 C.I. Inline 6. Could this be accurate?
Kieran K.
Farmville, VA
'47 ('46 Model/Art Deco) 1.5 Ton
Kieran #857788 06/09/2012 6:08 PM
could be, but it wouldn't be original .... you need to get all the numbers off it you can find and post them up to ID it, pictures would help too
Flxible #857800 06/09/2012 7:23 PM
Is the motor installed with motor mounts on the side? 292's had side mounts and they are not straight across from each other, they are offset. This should help identify it as a 292.
Your original motor would have two studs coming through the valve cover holding it in place. Side cover would be a large tin piece that extends all the way from valve cover (around the plugs) and down behind distrib. The 292 is a much later motor has two 6" tall side covers distrib is not centered along the block but way foreward.
1946 1/2-Ton Chevy
