| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85768 01/09/2004 6:51 PM | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | My lamp for the Signal Stat, 7 wire column mount after market turn signal on my '49 is always on, is that normal? Can I wire it to come on just when in use? I have a small radio shack buzzer to remind me to shut it off after turning.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#85769 01/09/2004 7:24 PM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | | | |
#85770 01/09/2004 8:32 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no, not normal - should blink when blinker is on - must be wired wrong, or has a short in unit
Bill | | |
#85771 01/10/2004 3:43 AM | Joined: May 2002 Posts: 8 Member | | Member Joined: May 2002 Posts: 8 | I'm sure someone will correct me if I'm wrong but I believe I read somewhere that you should use a 550 flasher then it will flash when its supposed to | | |
#85772 01/10/2004 4:55 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I have 2 Signal Stats and had the same problem with one of them that you are describing. My trouble turned out to be in the flasher. The flasher has three terminals: one for power in, one for load (in this case, the wire that goes to the Signal Stat that flashes the bulbs outside), and one for indicator. If you have the load and indicator wires switched around at the flasher, the indicator will always be on and the outside bulbs will not flash when directed to.
I ended up changing flashers to get my indicator to work right--they are cheap and available at NAPA or other real parts house. You MUST use a 3 prong flasher. | | |
#85773 01/10/2004 9:23 PM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=000504#000000
or search by Stovebolter number: 2131
Here in 'The Electrical Bay'
Topic: old aftermarket blinker
In that post Fred T posted a link to a website for the diagrams... and OldCarKook linked up some really nice high quality scans of some old signal stat literature... since the scans are ncie quality, they take awhile to download... so ya might as well save them.
dunno, if it will help or not...
-W | | |
