6 members (1955 1 Series, Stovebolt48, Otto Skorzeny, Uncles51, 55shaker, Cosmo), 172 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
#85768 01/09/2004 6:51 PM
ODSS President
ODSS President
C Online: Content
My lamp for the Signal Stat, 7 wire column mount after market turn signal on my '49 is always on, is that normal? Can I wire it to come on just when in use? I have a small radio shack buzzer to remind me to shut it off after turning.
~ Cosmo
1949 Chevy Half Ton
#85769 01/09/2004 7:24 PM
what's a sig stat?
#85770 01/09/2004 8:32 PM
no, not normal - should blink when blinker is on - must be wired wrong, or has a short in unit
#85771 01/10/2004 3:43 AM
I'm sure someone will correct me if I'm wrong but I believe I read somewhere that you should use a 550 flasher then it will flash when its supposed to
#85772 01/10/2004 4:55 AM
I have 2 Signal Stats and had the same problem with one of them that you are describing. My trouble turned out to be in the flasher. The flasher has three terminals: one for power in, one for load (in this case, the wire that goes to the Signal Stat that flashes the bulbs outside), and one for indicator. If you have the load and indicator wires switched around at the flasher, the indicator will always be on and the outside bulbs will not flash when directed to.
I ended up changing flashers to get my indicator to work right--they are cheap and available at NAPA or other real parts house. You MUST use a 3 prong flasher.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#85773 01/10/2004 9:23 PM
Socket Breaker
Socket Breaker
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=000504#000000
or search by Stovebolter number: 2131
Here in 'The Electrical Bay'
Topic: old aftermarket blinker
In that post Fred T posted a link to a website for the diagrams... and OldCarKook linked up some really nice high quality scans of some old signal stat literature... since the scans are ncie quality, they take awhile to download... so ya might as well save them.
dunno, if it will help or not...
-W
