2 members (54farmtruck, Rich'sToys), 115 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
I
I Offline
I have my 454 in my shop. I,m trying to get a new fuel pump on the engine. The rebuilder screwed a long bolt underneath the opening and going upwards into the engine. No clue why. How do install this thing ? If I remove that,..then I have a hole open in the block after the fuel pump is installed. Thanx for any help. Cheers !
3B Offline
Hy IsolationRide, if I remember correctly there is a 1/4" pipe thread hole below the fuel pump mount
That hole is to allow the fuel pump pushrod to be installed prior to installing the pump. Once the pump is in place, put a pipe plug in the hole with a little brush-on gasket sealer, and gently snug it into place. I believe it's a 3/8" pipe plug. Don't overdo tightening it, it's a tapered thread.
I
I Offline
Yes there is. I can,t get the arm into the whole with that there. If I remove it,...then I,m left with a hole after its installed.
I
I Offline
I have no clue where that is. I was given a box with all the parts. S$%tballz :P
