2 members (55shaker, Paul_WNC),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I have the chance to buy all the drive trane from an 85 Chevy 4wd. Are the rears to wide to fit under the 55-59 chassy?Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | They will stick out, not sure how much, but I can always spot a late model 4x4 set up. The pros shorten the axles to make it look right. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 |
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | But if you can afford to have a shop shorten the axles you will have an awesome set up. Disk brakes with aftermarket goodies like ARB air lockers and a closed knuckle. Use the later model engine, tranny and transfer case and you will have a great set up for off road and highway. Drop in an Atlas t-case, some air lockers and a winch and the truck would be almost unstoppable. One day I might build another 55 with all these. Maybe even go with coil spring set up like this one: Flying 55 | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Dogs51Burb, I've been wanting to learn about that truck ever since I ran across the photo. I need to get that issue. Does it go into detail on that truck? What can you tell me about it?
And do you know if it is for sale? | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 |
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I'm in love.
Thanks for sending. | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | lostmy47, My Son told me you started talking to him about that flying 55'. You found out He knew all about it, what a small world in cyberspace! More pics of that 55'
| | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | Yep, pretty small. We had a pretty good laugh over it. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | it may be a small world, but I wouldn't want to paint it. | | |
