3 members (Lostbuthaulinass, MNSmith, festerhairball), 99 guests, and 2 robots.
Topics128,057
Posts1,055,814
#856368 06/04/2012 2:09 AM
Can I put a solenoid onto a foot start starter?(1959 235)
Dustman #856370 06/04/2012 2:24 AM
Nope, the linkage and switching system is totally different. A passenger car starter will have the solenoid-type engagement, either 6 or 12 volt. I believe the starter for the Powerglide-equipped cars has a different nose cone than the one for the standard shift, and is very scarce. Use the stick shift car starter.
It is not the Power Glide starter that has a different nose, it is the truck Hydramatic.
1938-62 216, 235, and 261 starters will all bolt up the same(except Hydramatic). They will need to match the 6 or 12 volt flywheel though.
On your 59 you would need a 1960-62 truck starter or a 1955-62 pass starter.
My Blog
