| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 41 New Guy | | New Guy Joined: May 2009 Posts: 41 | Can I put a solenoid onto a foot start starter?(1959 235) | | | | | Joined: Feb 2004 Posts: 29,743 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,743 | Nope, the linkage and switching system is totally different. A passenger car starter will have the solenoid-type engagement, either 6 or 12 volt. I believe the starter for the Powerglide-equipped cars has a different nose cone than the one for the standard shift, and is very scarce. Use the stick shift car starter. Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is not the Power Glide starter that has a different nose, it is the truck Hydramatic. 1938-62 216, 235, and 261 starters will all bolt up the same(except Hydramatic). They will need to match the 6 or 12 volt flywheel though. On your 59 you would need a 1960-62 truck starter or a 1955-62 pass starter.
See the USA in your vintage Chevrolet! My Blog | | |
