1 members (Hotrod Lincoln),
55
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thinking about adding dual intake and dual Fentons for next season.
But what carbs should I use ? Is there any tested setup for a 2 ton with 261 ?
/Ulf My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I had great success with both Rochester B, and Carter W-1s. That was on a 216, right now, I'm gearing up to put two W-1s on my 235, with a vintage Edmunds intake.
As long as the carbs are matched, you should have no troubles. Just take your time when tuning and syncing them, the directions in the California Bill book are great. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hey,Lastchance! I JUST installed my Fentons and dual stacks on my '55 2nd Series 6500. You'll also NEED the heat kit,to replace the heat-riser in the stock manifold. I have a 261,too. I'm using my stock intake,and single Carter. The truck RUNS GREAT! Better performance and a little better gas mileage! Oh,and the BEST part,is the way she sounds! I am VERY PLEASED with my set-up. I'm not planning on up-grading to dual carbs on my truck. Hope this helps. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Hi, thanks for the info. I had a Chevy Styleline 1950 before. With a 235 and pg. I did that conversion, dual Fentons and heat riser kit. Worked really fine.
the thing I am most confused about is carbs. Carter you said, which one do you use ?
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | |
