Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MNSmith, dt235sd, J Lucas, Hotrod Lincoln), 199 guests, and 6 robots.
Topics128,288
Posts1,058,579
Members48,492
Hi all, I am looking for several parts for my front motor mount for my 1946 3/4 ton with a 216. I have a new top piece and a new rubber mount, but I need to find the flat inside plate that sits on top of the rubber mount and below the top piece. I also need the bottom steel mount cup that holds all the parts. I have tried all the old car parts, to no avail...everyone has the two parts I have...any help would be greatly appreciated...even used ones would do...Thanks John
[email protected] 772-766-9790
jkully, if you will post this in the Parts Wanted forum you'll have lot better luck.
I suspect a moderator may move it for you?
1 Offline
I would suggest you also look at: www.chevysoftheforties.com They usually stock items like you are looking for.
Normbc9
