4 members (Chip O, Hotrod Lincoln, TooMany2count, 1 invisible), 88 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#855176 05/30/2012 7:31 AM
Seeing the question about hinges got me to thinking,maybe I could rebuild mine on my '54 GMC. I really only need to do the left side-the right side works just like new. thumbs_up
headscratch Has anyone here had any experience,good or bad,in replacing hinge pins and hold-open springs? What tricks will make it easier to do? I already figured out using my engine hoist to hold the door up while removing and replacing hinges. (Always let the machine do the work when possible.)
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Hey Speed,
I'm obviously interested as well. I haven't done it yet but when I was at the Monroe WA swapmeet I meet up with a guy named Bob in Port Orchard who had done this so I had him talk me through the process. What he did was remove the original pin (push it out / drill it out), Then drill the hole larger and re-assemble with new larger pins. I believe he bought the kit from Jim Carter and the instructions tell you what size of drill bit to use.
Now lets hope our Stovebolt experts chime in, add more, correct me if necessary or inform us of alternate methods.
Greg
Gregger #855843 06/02/2012 12:49 AM
Awesome!
Thanks Brad.
