Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
8 members (Bill Hanlon, 66flea, WICruiser, VEW, GMCJammer51, 3 invisible), 561 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
I have a painless harness wired before I bought truck.It will start truck fine put it will not shut it off I have to pull wire going into distributor? I rigged up a toggle switch. I just printed a schematic hopefully I can figure out anybody had this issue?
What kind of charging system do you have? Some alternator/regulator combinations have a capability of feeding back to the ignition system when the switch is turned off. A resistor or diode in the exciter circuit to the alternator usually solves the run-on problem.
You could also speak with the Tech guys at Painless Wiring. I found them very helpful when I ran into questions.
1940 Chevy KC 1/2-Ton
HotRod Lincoln has nailed it...You need a diode in the
correct orientation on that exciter circuit.
Same issue I had ... Using a Painless harness and an
MSD ignition. MSD even supplies the diode in their box of goodies to alleviate the problem. I believe if you go
to their website and dig, you'll find out the value of the
diode to be used. I believe Radio Shack sells the correct ones, too.
If I get a chance to check I'll report back on the diode specs. Takes about 5 minutes to insert it and you're good to go.
mike
What you have is feedback from the alternator. Put in a diode on the ignition wire to the alternator with the arrow pointing toward the alternator. The Radio Shack number is 276-1661 for a pack of 4, about 5 bucks.They have it listed as a rectifier diode. That will do it.
Thanks all!!!! I will try it.
It worked thanks guys!!
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.248s Queries: 14 (0.062s) Memory: 0.6238 MB (Peak: 0.6785 MB) Data Comp: Zlib Server Time: 2025-09-22 12:49:55 UTC
Valid HTML 5 and Valid CSS
