0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 16 New Guy | | New Guy Joined: Jan 2012 Posts: 16 | I have a painless harness wired before I bought truck.It will start truck fine put it will not shut it off I have to pull wire going into distributor? I rigged up a toggle switch. I just printed a schematic hopefully I can figure out anybody had this issue? | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | What kind of charging system do you have? Some alternator/regulator combinations have a capability of feeding back to the ignition system when the switch is turned off. A resistor or diode in the exciter circuit to the alternator usually solves the run-on problem. Jerry
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | You could also speak with the Tech guys at Painless Wiring. I found them very helpful when I ran into questions. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | HotRod Lincoln has nailed it...You need a diode in the correct orientation on that exciter circuit.
Same issue I had ... Using a Painless harness and an MSD ignition. MSD even supplies the diode in their box of goodies to alleviate the problem. I believe if you go to their website and dig, you'll find out the value of the diode to be used. I believe Radio Shack sells the correct ones, too. If I get a chance to check I'll report back on the diode specs. Takes about 5 minutes to insert it and you're good to go.
mike
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | What you have is feedback from the alternator. Put in a diode on the ignition wire to the alternator with the arrow pointing toward the alternator. The Radio Shack number is 276-1661 for a pack of 4, about 5 bucks.They have it listed as a rectifier diode. That will do it. | | | | | Joined: Jan 2012 Posts: 16 New Guy | | New Guy Joined: Jan 2012 Posts: 16 | Thanks all!!!! I will try it. | | | | | Joined: Jan 2012 Posts: 16 New Guy | | New Guy Joined: Jan 2012 Posts: 16 | | | |
