0 members (),
133
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 3 New Guy | | New Guy Joined: Mar 2012 Posts: 3 | I have a 35 pickup and would like to move it to a more modern running gear and retain the 17" 6 lug wire wheels. Is it a fairly easy swap? A 2dr Tahoe with 4wd is the right wheelbase and has 6 lug wheels. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Those wheels are the same bolt size as the earlier GM trucks, not sure if the newer Tahoe went metric or not. I suspect the frame might be a bit wide to accommodate the running boards but if you are good with torch and welder it can be done.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Tires will stick out past the fenders in the front.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The bolt pattern is the same, but you will find, as the others mention, that the frame will be too wide to fit comfortably under the older cab. The track width is much wider, using the old style low offset wheels will make this even more noticable in addition to altering the scrub raduis/handling. The older wheels may not clear the brakes on the Tahoe frame.
Bill Burmeister | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Mar 2012 Posts: 3 New Guy | | New Guy Joined: Mar 2012 Posts: 3 | Do any of the s-10's, blazers, or trailblazers have 6 lug wheels? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Show us some pictures of what you have and maybe we can come up with some better ideas for you. Six lug wheels is the least of your worries.
| | | | | Joined: Dec 2011 Posts: 2 New Guy | | New Guy Joined: Dec 2011 Posts: 2 | Here's some food for thought. If you really want to use the Tahoe frame, cut the rivets/welds from the crossmembers and steering linkage, cut them to length to make them shorter, then weld/rivet/bolt them back together. It's too long too, then you'll have to shorten the frame. I'm in the same delima, my '41 is going to get another frame under it. I just haven't made up my mind what to do. Good luck | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Do any of the s-10's, blazers, or trailblazers have 6 lug wheels? S10s and Blazers are all 5 lug. Trailblazers are 6 lug, but they use a smaller pattern. A Colorado might be a better choice, as it is 6 lug and about the same width as an S10.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Bad fit!!! You might as well use a 1975 Lincoln Continental. Heavy price to pay for disc brakes and IFS.
~Jim
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | other prob you have besides the track being too wide early chevy trucks have a fairly open veiw to see the front suspention putting that frame under it your A-arms are going to look rediculusly large you can get away with it alot easyer with the S-10 i have seen trucks where in not in part they did use the front crossmember from a full size late chevy and never seen one that looked good "personal opinion only"
1937 1/2 ton
