7 members (Wally / Montana, Gray_Ghost, JW51, Otto Skorzeny, kades51, Bill Hanlon, 1 invisible),
98
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,724 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Was thinking about getting some kind of rubber mat to place under the truck in the unlikely event oil will drip on the floor.
Been looking online
Can anyone make a recommendation? Prices are all over the place online. Just looking for 2 mats one for engine and one for rear.
Was thinking about something that I can easily wipe the oil up then hose off in the driveway.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check your local building supply and flooring stores for rubber mats and runners, there's stuff available 3 and 4' wide priced by the foot
Bill | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | For oil drips? I get them in the mail all the time. Floor mats Grigg | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I use the metal ones from the local auto parts store, about $10 ea. They last forever unless you run over them too may times.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No joke, disposable diapers (or, Depends).
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks for all the suggestions. I had been using a plastic catch pan. Went to lowes and got the rubber carpet runner. $2.84 per foot. 3ft wide pic pic should make clean up easier. thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....I'm so tight that I like things to last forever so i favor the metal pans, $10, from the local parts house. I also like them for doing brake work ect as it's a "catch all" for stuff that normally gets on the floor for clean up. I just wipe the pan off and continue to use it. I've had mine for years! | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | My truck is outside. I buy the kitty litter filler at the grocery store to soak up the oil.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | For oil drips? I get them in the mail all the time. Floor mats Grigg  Like Grigg's idea best. Can't get any cheaper than free cardboard!
Drew
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | For oil drips? I get them in the mail all the time. Floor mats Grigg  Like Grigg's idea best. Can't get any cheaper than free cardboard! but in case of major spills, have a piece of poly under it  Bill | | |
