2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 10 New Guy | | New Guy Joined: May 2010 Posts: 10 | I brought out a 1946 2-ton from the family farm in Kansas where it sat for 10 years behind the barn. After a year in my shop, it is is running and driving well. Can someone tell me how the dump system works on this thing? One big lever in the floor aft of the shifter. PTO or elec-hyd? Still lots of little things to tinker with. But It Drives!! | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | It's hard to say without knowing what dump system you have It shouldnt be electric unless someone has put a more modern dump hoist on the truck. Chances are it is a PTO driven hoist which runs off the transmission. If it is there should be a knob on the dash or another lever which operates the PTO, the big lever in the floor is what makes it go up & down. All with the transmission in neutral of course. Got any pictures? | | | | | Joined: May 2010 Posts: 10 New Guy | | New Guy Joined: May 2010 Posts: 10 | HA!!!! It Works!!! Not bad for sitting for 15 years. Yep, PTO type with knob next to drive column. Very nice. Thanks. I'll get some pictures up soon. | | | | | Joined: May 2010 Posts: 10 New Guy | | New Guy Joined: May 2010 Posts: 10 | Got some pics up. Now cleaning 66 years of grease of the hummer. Any Idea what kind of oil goes in the lift system?
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I think basically any type of hydraulic fluid should work. If you have to raise the bed to add it, be SURE to block it securely so it don't come down on you and turn your wife into a widow! Also, leave out the plug the first time you let it back down. That way, if you overfill it, the excess fluid can escape and not blow the seals out. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | That truck is in really nice shape! I like the video. Now im jealous! | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Ditto that!! I'd take that truck any day! | | |
