Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Guitplayer, CuzzFuzz, 1 invisible), 38 guests, and 2 robots.
Topics128,018
Posts1,055,259
Members48,417
#853198 05/22/2012 7:43 AM
I'll soon be starting a restoration on my 1957 GMC 450. I'll keep you updated on my progress, I'm sure I'll have lots of questions once I get into it. Here's some photos.
Greengrass #853211 05/22/2012 10:48 AM
Camp Commandant
Camp Commandant
Nice! What are your plans for it? Yes keep us posted and take lots of pictures.
~ Billy
1959 GMC 860 | Pictures
I'm going to get it roadworthy and painted for the time being. I'll do a restoration as time allows.
Wow, that truck is big! What size of engine sits under the hood?
1951 1 Ton Completed
The truck has a 347 Pontiac engine with a 5 & 2. The truck is all original with very low miles.
That is a great truck! Can't wait to see your progress.
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276
"If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
OVRTRQD #853505 05/23/2012 5:30 PM
Crusing in the Passing Lane
Nice truck, apparently the earlier? ones came w/ GM 503 gassers; I'm looking for one w/ a 4-71.
EdPruss #853516 05/23/2012 6:18 PM
How is the pump driven? My '46 has a drive shaft pto drive that I'm assuming was for a pump at one time. It would be interesting if yours is set up the same.
That is a nice looking truck.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
The pump is driven directly from the driveshaft. The pump has a drive out the back that connects to the rear diff. I will be removing the pump and getting the driveshaft lengthened and installing a steady bearing.
Love the look of the ol girl.
Current project . . . 1960 LB stepide Chevy
Is the parking brake located on the back of the pump transfer case? If so you'll need to make the one on the transmission work again.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #853961 05/25/2012 6:28 AM
Fortunately the park brake is still working on the rear of the transmission, however the left rear brake is giving me some grief. It was dragging when I brought the truck home and it has seized up now. Hopefully I can get it apart to see what the problem is.
That joint in the driveshaft where the pump is, is a great place to put a Brownie, in case you have very low rear gears.
EdPruss #854348 05/27/2012 3:39 AM
That's a great idea Ed, I'll look into that before I have the driveshaft lengthened. The truck does have a 2 speed rear and I don't know which would be better for highway driving.
Was there a second parking brake on the rear drive shaft? If not how did they keep the truck from rolling while pumping? It does have hrdraulic brakes doesn't it?
I bet the rear will let you go at least 55 mph...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #854355 05/27/2012 4:02 AM
There was a Mico Lever Lock system on the truck, it was taken off when the firetruck equipment was removed. There are still some of the parts connected on the truck's brake lines so I have to change a couple of them.
