Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#854259 05/26/2012 5:34 PM
Any info on how to install a horn? Ive got the original steering wheel, with the button, but no switch. Do the wires run inside the steering column? Where did the horn itself mount?
It's not the weight of the load, that breaks your back. It's how you carry it.
49oldandslow #854265 05/26/2012 6:17 PM
The Horn mounts to a boss on the exhaust manifold if a single, to the firewall if there are two horns (Hi/Lo tone).
http://good-times.webshots.com/photo/2509864860102454676YABHOn
The entire switch assembly for the horn is shown below.
http://good-times.webshots.com/photo/2377964070102454676NwgCMi
The spring with plastic collar goes into a recess in the steering wheel and contacts the mast bearing (horn wire is attached to it). The horn wire comes out of the column under the dash here.
http://good-times.webshots.com/photo/2980430340102454676PPNeLa
