| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85422 03/28/2004 6:38 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | My speedometer began making this horrible noise then the needle got pinned and finally broke. I had to disconnect the cable to continue driving. I finally took it apart but broke the thin shaft that drives the needle in the process. I "fixed" it by supergluing a very thin tube (from a watch band connector) over the two broken halves. It's a very iffy fix.
Does anybody have a speedo for a 62, PU? I looked in the swap meet but no luck.
delete my account and pictures
#85423 03/28/2004 7:17 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Tab I had the same thing happen on my '62 too. :o I found a replacement guage cluster on Ebay, these are always on there. 1960-63 Chevy guage clusters are the same. They did make a few different ones. The first one has the dummy lights, the second one had needle temp + fuel gauges, the third one had 4 needle guages with or without the vacumm guage + factory tach. I hope this helps. David
My truck don't leak oil, it just marks its teritory.
#85424 03/29/2004 6:41 AM | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Had exactly the same thing happen to my 62 flatbed and I fixed it the same way too, but the needle just broke again. Found a 61 Tow Truck in a wrecking yard nearby but they want $35.00 for the instrument cluster so I think I'll check e-bay also. Thanks for the tip.
Dave
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | |
#85425 03/29/2004 6:52 AM | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Hey David, How did you search for the instrument cluster on e-bay? I tried using 'Chevy instrument cluster' 'Chevy speedometer' etc. but came up with nada. I haven't surfed e-bay very much...any suggestions? ( I did find a couple of good deals on some old 'bolts though) :confused: :confused:
#85426 03/29/2004 11:49 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Originally posted by knokeydv: Hey David, How did you search for the instrument cluster on e-bay? I tried using 'Chevy instrument cluster' 'Chevy speedometer' etc. but came up with nada. I haven't surfed e-bay very much...any suggestions? ( I did find a couple of good deals on some old 'bolts though) :confused: :confused: Hi Dave, I type in a few different searches, for example i'll type "62 chevy truck". I do this from 60-66 followed by chevy truck. If I didn't find what I was looking for in that search, I'll delete the "chevy truck", and type in "GMC".I'll go through 60-66 all over again. lol  I also use "1960 chevy truck" + "1960 GMC", and get a bunch of hits too, and have found a few parts that I needed using these searches. David
