| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Please tell me if i'm wrong but i think this is a 54-55 engine correct? not a two bolt valve cover and it does have the high water pump. Engine | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely you are correct. The block and head casting codes and the engine serial number would be the best ID.
It might be a 53 with later head. Or a later engine with a water pump relocation plate. Both of these possibilities are unlikely.
As I recall, that is a 1954/55 truck with some modifications related to a transplanted radiator.
| | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | It is according to grill but the registration has an lea number on it. I'm told that means a 53 engine...
Haven't been able to get to truck to confirm numbers myself yet...
2 kids and not keeping it on my property mean i've had all of 15 minutes with it since i bought it.... sigh. | | |
