2 members (Hotrod Lincoln, Tronman), 167 guests, and 3 robots.
Topics128,257
Posts1,058,017
Members48,479
#853257 05/22/2012 3:51 PM
Did the hinges come stock with bushings in them or is this used to rebuild them?
Stock had no bushings. Some rebuilding kits use bushings and some just use a larger pin.
Chuck
I just finished rebuilding my hinges without using bushings. I order the oversize pins from Jim Carter. The pins I received did not have the knurling and sizing problem that is ourlined in the Tech Tip article. The pins were .001 smaller than a standard SAE drill bit size (forget size, 11/32?). Pins fit snug and knurling lenght was perfect. Pins must be cut to proper length.
DavidF #853365 05/22/2012 11:52 PM
Thank you
