7 members (KEVINSKI, Otto Skorzeny, Tronman, Charles in CA, Goach2, 66flea, 1 invisible),
233
Mod | | | Forums66 Topics128,257 Posts1,058,015 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | Did the hinges come stock with bushings in them or is this used to rebuild them? | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Stock had no bushings. Some rebuilding kits use bushings and some just use a larger pin.
Chuck | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I just finished rebuilding my hinges without using bushings. I order the oversize pins from Jim Carter. The pins I received did not have the knurling and sizing problem that is ourlined in the Tech Tip article. The pins were .001 smaller than a standard SAE drill bit size (forget size, 11/32?). Pins fit snug and knurling lenght was perfect. Pins must be cut to proper length. | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | | | |
