0 members (),
177
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 77 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 77 | Hey all I am wanting to switch the rear end gears out of my 52 truck without changing the rear end with a newer one. At one time I knew Jim Carters had a higher gear ratio set I culd swap for mine. Can't find it on their website now. Any one know who sells these? Thanks!
John Kinser
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | John, If you are referring to a 3100 (1/2 ton) enclosed driveshaft rear-end, Patrick's in AZ makes a 3.55 ring&pinion replacement (and separate bearings/bushings/seals installation kit). Almost all thew reproduction parts vendors sell Patrick's 3.55 gears, but call Patrick directly and ask for a Stovebolt.com discount (because you have read such nice things about him on this discussion board). http://www.patricksantiquecars.com/ | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Once have the gears Brother Tim mentions above, check out my Webshots page. I tried to take photos each step along the way.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi sweet. Were the gears hard to replace. Could a decent shade tree mechanic (me) do the job? Or is it better to farm out the job?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Oh. How long did it take? More or less
Thanks again
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | If you have a good attention to detail, Patrick has written directions that are easy to follow. They are step by step and the photos on my Webshots page kind of go along with them.
I have done 4 sets now without any issues. I'd say give it a shot. Feel free to send me a PM or start a thread here if you have any questions.
If you have no major cleaning to do from any bearing failures, and you have a tool to remove the bushing, this is a job that can be done in a few hours. Realistically for a first timer, I'd say it would be a good weekend project.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I assume the bushing is the 'okie bushing'?
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Correct. The most frustrating part of the job for me the first time was getting this bushing out. I had a buddy who own a metal lathe make a tool that fits on the end of a threaded pipe to remove mine. Here is a PIC There are other ways to remove this bushing. Take your time and this job can be done yourself!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You can buy a removal tool from Jim Carter for $53. I also think there's a jobber who rents them with a deposit, but not sure who it is.
Drew
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jim Carter's bushing and seal removal tool (50% of the $53 is returned as a gift certificate when you return tool). As SWEET states above, this tool is only needed when you need to remove an old original bushing or a worn-out Okie bushing AND you are not taking the rear end apart. If you are taking the rear end apart, you can push out the old bushing (original or Okie) from the inside of the disassembled torque-tube. I have done this twice with a 5'-6' length of metal plumbing pipe (I forget the diameter - 1.25" to 2"). You need the largest diameter pipe that will fit inside the torque-tube without scraping the wall - a diameter that is larger than the diameter of the driveshaft end. You simple place the plumbing pipe inside the torque tube and hammer the pipe against the inside surface of the bushing/seal. Note: at the end of the earlier torque-tubes there is a "stay-pin" that holds/locks the original bushing in place. That pin has to be removed (maybe someone will post the years in which this pin was used)? I found SWEET's photos to be quite helpful. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Some of the TT have a ring inside (mine did) so you need to be careful not to damage that. This ring seats the bushing during installation. I haven't come across a pin yet......
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | If the torque tube has a ring then it dictates which way the bushing goes in? Otherwise, it could be inserted backwards?
Thanks to all
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | You can put the bushing in backwards. Patrick's directions does a good job preventing this. Basically the end with the seal goes in first, the larger end faces outwards so that the yoke can fit inside. If you can't slip the yoke between the splines of the prop shaft and the bushing, the bushing is in backwards.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for all the advice and pictures. They are a great help
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | That pin has to be removed (maybe someone will post the years in which this pin was used)?Under group numbers 5.450 and 5.451 DOWEL & KITS, Propeller Shaft Bushing and Seal (look at "NOTE:") Looks like all 1929-1950 1st design torque tube bushings had a "stay-pin"/Dowels. From 1950 to 1954 2nd design torque tube bushings , all bushings were press fit. More info: 1949-53 car shop manual under "REPAIRS" And Here 1948-51 truck shop manual under "Replacement (1950-51)" Oil Seal for all years was press fit. Thanks | | |
