1 members (TUTS 59),
55
Mod | | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 6 New Guy | | New Guy Joined: May 2012 Posts: 6 | 1. Battery is disconnected right so I plug it in so my issue is rear tail light stay on the switch is off.?? Bad switch it doesint sit flush but pulls out twice that's parking then head light right..
2. Torsion bars are cut flush with crossmember I'm guessing that's y its a Pepsi can off the ground,so I've been looking for another torsion bars can't find any wer how do I get my suspension back to lower it the right way spindals,ect ?? 3.any places sell complete bolt on front suspension that will fit and eliminate the torsion bar issue..it doesn't even have room for springs or seat for them If u sell any airride kits,diskbrakes,suspentions,805-863-7157 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | On #2, have you attempted to adjust the bars back up? There's an adjuster screw (should have a 3/4" hex head) on the crossmember. Unless the bars have been clocked incorrectly, you should be able to get the ride hight back to spec by cranking the bolt in. You may want to hit it with some Kroil or PB before you try it. For #3, an entire front crossmember from a '63-'87 Chevrolet truck can be adapted to your frame.'71-'87 would get you disk brakes in 5 lug.
Bill Burmeister | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | If you’re saying someone cut the torsion bars off and you need replacements. I think you’ll find it easier to replace the front suspension. Torsion bars can only be found used, and in many trucks they are frozen in place. If you’re interested in swapping to the newer coil spring front suspension, this thread may prove helpful. It shows how I did the installation in my 1960 GMC; http://67-72chevytrucks.com/vboard/showthread.php?t=366828 | | | | | Joined: May 2012 Posts: 6 New Guy | | New Guy Joined: May 2012 Posts: 6 | Thx guys relly helpfull I love this site | | |
