6 members (55shaker, Gray_Ghost, 51sub, JW51, Stovebolt48, 1 invisible), 53 guests, and 2 robots.
Topics128,041
Posts1,055,593
#852599 05/19/2012 4:04 PM
I cannot free / open the cowl on the side of the cab. It'll open about a 1/4" of an inch. The lever in the cab, moves about a 1/4" as well. I'm sure it's just rusted, but can't find anyway to the hinge. Any ideas?
It's not the weight of the load, that breaks your back. It's how you carry it.
Use a flashlight and look between the vents from the inside. Use a penetrating spray (one with a tube) to shoot the area.
Here is a picture of the assembly removed. It hinges at the rivets. Yours may or may not have the springs. Spray and let it sit. You don't want to use undo force because the bracket it bolts to is spot welded to the cowl inside, if it breaks it will be bad news.
http://good-times.webshots.com/photo/2261760620102454676QYmpkn
Brad Allen #852620 05/19/2012 4:37 PM
Thanks Brad, did that this am, just need to let the PB Blaster do it's work.
