1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 27 New Guy | | New Guy Joined: Apr 2012 Posts: 27 | I cannot free / open the cowl on the side of the cab. It'll open about a 1/4" of an inch. The lever in the cab, moves about a 1/4" as well. I'm sure it's just rusted, but can't find anyway to the hinge. Any ideas?
It's not the weight of the load, that breaks your back. It's how you carry it.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Use a flashlight and look between the vents from the inside. Use a penetrating spray (one with a tube) to shoot the area. Here is a picture of the assembly removed. It hinges at the rivets. Yours may or may not have the springs. Spray and let it sit. You don't want to use undo force because the bracket it bolts to is spot welded to the cowl inside, if it breaks it will be bad news. http://good-times.webshots.com/photo/2261760620102454676QYmpkn | | | | | Joined: Apr 2012 Posts: 27 New Guy | | New Guy Joined: Apr 2012 Posts: 27 | Thanks Brad, did that this am, just need to let the PB Blaster do it's work.
