0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#779529 09/10/2011 2:29 AM
The cab on my '55 1st series sits low on the drivers side. I measured the box and it is level front to back and left to right. I measured the cab and the drivers front and back is 1" lower than the passenger side. I want to fix the problem. Need input.
thanks, Larry
nels1954 #779544 09/10/2011 2:55 AM
check your cab mounts for rotten or missing rubber parts .... get some body shims at a FLAPS and shim it up - pay attention to what that does to fit of the front sheet metal, might need to drop the other side a bit to split the difference
squeeze #852042 05/17/2012 2:26 AM
I'm finally getting back to the cab problem. There is no rot in the truck. The frame sits level. The box sits level. The exact difference is 3/4 inch in the cab. There are no shims between the cab bottom and the frame top. I plan to shim the one side. It may make the problem worse.
nels1954 #852235 05/18/2012 12:14 AM
I removed the bolts and jacked up the one side of the cab. Placed shims between the cab and the frame. Replaced the bolts. The cab now sits level. As you said that there will be other areas that will be affected. The front end sits fine. The hood opens and closes fine. I'll need to adjust the door.
