| | | Forums66 Topics128,196 Posts1,057,398 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | I'm tightening my center bolt on my AC S-6 oil filter but still getting a little leakage around cap. Gasket new and good. How tight do I dare torque down center bolt? Mine looks like this http://www.stovebolt.com/techtips/engines/oil%20filters/35.jpg Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It shouldn't take a lot of torque to seal the gasket. the washer on top can be a problem getting it to seal. I would look at the pattern that is impressed on the gasket to see if there is a problem. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Make sure you put some oil on both side of the gasket before you put it on. Seems to help seal it.
Kurt | | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | Thanks guys, I have a large gasket on underside of lid where it meets the canister and a small gasket/washer piece on top of spring and bottom side of lid. Is this the way it is suppose to be? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You want a gasket between the head of the bolt and the top. Usually this is in the form of a washer. | | |
