0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | can anyone identify this oil filter setup on my 46 1/2 ton it has both fittings on the bottom of the tank and its been bypassed, i need to know which lines go where and what type of filter setup it is...thanks http://s629.photobucket.com/albums/uu14/kurtdh519/oil%20filter/ | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Have you opened it up? I'm going to guess the hole that's offset to one side is the inlet, and supplies oil to the outside of the filter element, and the return line will come out of the center. There's probably a small hole somewhere in the center pipe that acts as a restrictor to prevent oil pressure loss and control the flow through the filter. Finding a correct-sized filter element might be a challenge. Jerry
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Wow, that thing is huge! Looks really cool though, I like it! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Depending on the setup, the hole to control flow through the filter can be either in the lines themselves or in the filter housing.
You need to make sure there is this type of restriction, so that the filter doesn't fill up with oil and starve your bearings. | | | | | Joined: Jul 2011 Posts: 24 New Guy | | New Guy Joined: Jul 2011 Posts: 24 | Not sure if this helps or not, but here is a great article on oil filters...Looks like it could be an S-2 type filter (1946-48). << Check that section out. I am referring to images 17 & 18. Great oil filter debate Oops, almost forgot...Installation instructions are are the bottom of the article. : ) Thanks, -Paul
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | ok, i got it apart, and it has the hole in the pipe for the restriction but i need to know which lines hook to it from the motor since I have 4 different oil lines from the bypass that someone put on it, thats why, i need a picture of a 216 engine on the drivers side that shows the oil line setup
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | The top or lid on hoozat's filter is shaped different than the lid pictured in the S-2 description...
Professional Novice
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | mine isnt an s-2 because all my lines go thru the bottom of the tank, i just dont know which line off the motor goes to the in and which is the return
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Of the two ports or threaded holes in the block, only 1 has pressure as it comes from the oil galley. The other is just a drain; a hole through the block skirt into the crankcase - the return line goes there. It is the lower hole. (Maybe you know that already?) Maybe the pictures in this Tech Tip will help. Good luck.
Professional Novice
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | We had one of these on a 1949 Chevy cab over with a 235 six in it. It was an optional oil filter. In those days those were an optional item. Filters for that can are still available from WIX. Normbc9 | | |
